RCU Forums - View Single Post - Fuel Dot installation help needed
Old 12-14-2005 | 07:40 AM
osprey1's Avatar
osprey1
Default RE: Fuel Dot installation help needed
I too am fed up with easy fuelers but my planes are set up with two lines to the tank.
My tanks access to add the third line isn't good.
With a new build I wil add the third line.
My question is: Can I just tee a fuel dot into the carb. line?
I know fuel will travel in both directions, towards the carb. and towards the tank.
Will the fuel tend to fill the tank rather than go thru the carb.?
Once in the carb. will it continue into the cylinder and then create fuel lock in the engine?
Thanks.
Looking for an easy rework.
