RCU Forums - View Single Post - Fuel Dot installation help needed
Old 12-14-2005 | 08:22 AM
da Rock
Default RE: Fuel Dot installation help needed
Once in the carb. will it continue into the cylinder and then create fuel lock in the engine?
It won't if you turn your prop so that the intake hole in the crank is closed. But the amount of fuel that's going to be pressured through the spray bar into that crank hole depends on how hard you pump the fuel into the airplane. Sometimes if you pump easy there won't be any fuel out the spray bar. Also, the mounting direction of the engine may tend to slowly turn the crank back open, or it might hold it closed for you. And obviously if your carb opening is pointing toward the ground any fuel flowing out the spray bar is going to drip out of the carb.
