RCU Forums - View Single Post - Install the DEPS elevator system in a painted fuse
Old 12-14-2005 | 02:18 PM
  #46
mprediger
Default RE: Install the DEPS elevator system in a painted fuse
Another option for connecting 2 CF rods.. .070 rods - titanium rod 4/40 fittings - MK BB rod ends --- 2mm screw through 1 rod end into threaded alum servo arm 2nd rod end lock nut and locktite all around. Been using this for over a year now with solid result. Also if one rod is damaged it is easier to repair this setup
mike
