RCU Forums - View Single Post - Fuel Dot installation help needed
Old 12-14-2005 | 05:22 PM
desmobob
Default RE: Fuel Dot installation help needed
ORIGINAL: osprey1
Thanks for all the advice. I will adhere.
I have no problem putting in the third line on a new build.
Its just getting access to my fuel tanks at this time.
Alos, I like to pump out my tanks at the end of the day so I think I will
have to put a clunk on the third fill line.
The third line is the way to go.
I've been doing something different other than using a second clunk. I angle the third brass fuel tube toward a back corner of the tank and run a piece of silicone fuel tubing from it so it's a little bit short of a back corner. I cut the tubing at an angle so the opening is on the bottom of the tubing, parallel with the tank bottom. The fuel pick-up clunk can easily swing back and forth behind it, and you can still empty your tank almost completely dry at the end of the day by tilting the model just a bit toward the side you have the third line angled toward.
No need to buy extra clunks, and no worries about the two clunk lines getting snarled up somehow during aggressive aerobatics or exciting landings like mine....
Good flying,
desmobob
Good flying,
desmobob
