RCU Forums - View Single Post - Maratuka Stuka
Thread: Maratuka Stuka
Old 11-15-2002 | 06:24 PM
Roby
Default Maratuka Stuka
Isn't this a "Royal" kit made under a different name ?
I did build and fly the Royal Stuka for a time . When that
plane was in the air it drew much attention.
I did the aileron and flap hinges as per plan . In my opinion
they looked fairly good and worked well.
The only problem I had with that plane is that if you
drag a wing tip on landing it will break the tip off the
aileron at the outboard hinge position.
In the 4 years I flew it the ailerons got replaced 3 times
Regards
Roby
