1st choice for 2nd plane?
the original "das ugly stick" was inspierdin the WWI german plane Fokker eindeker is has a fus type of the box-kites of that era although has semi or simetrical wings, the desing can take a lot of punishment because of itīs boxy fuselage and is a mid wing, mid wing is easier to fly than low wing and a perfect transition from high wing trainer types plane.
the GP dazzler and the SIG ES-40 wonīt take the punishment relate to landing a faster plane as good as a stickīs BOXY type planes.-
there are even sticks desing to be extremely aebatic such as the super stick from H9.-
STICKS are a perfect second plane is you did good with your trainer, going to a scale aerobatic plane in the 40 range as a second plane is o.k. if you were aGOOD studentonly!!!
