RE: JR 10X Programming help needed
I had my 9303 setup like that but I wanted to be able to setup crow, flaps, etc...
I was able to program the radio successfully last night so now I have several mixes available. Now I have quadan flaps setup correctly so when the mix switch is on, all 4 surfaces (flaps and Ails) act as one... Flip that off and hit the gear/mix, I have Elev to flaps for those super tight turns,
I also have crow setup on the flaps switch that can be turned off and on...
The left slider is set to operate the flaps independently when the mixes are either on or off....
Should make for some insane 3D now!!!!!!!!!!!!!!!
