RCU Forums - View Single Post - JR 10X Programming help needed
Old 12-15-2005 | 11:51 AM
tl3
Default RE: JR 10X Programming help needed
Method 2:
If your set on using the right side slider as your control, you can accomplish that through the following steps.
1) As before, leave your ail. servos on matchboxes.
2) Select code 17 - Function select - inhibit all but the aux 3 channel.
3) Plug right ail into the ail slot on the rx. Plug the left ail lead into aux 3 slot.
4) Choose any availble programable mix - codes 51 - 55.
5) Create a mix for ail to aux 3. You need to select channel 2 as master and channel 8 as slave.
6) Use +,- values to make sure the slave travel matches that of the master.
7) Press "page" twice so you get to the screen that allows to activate trim - you want ail trim to effect both ailerons - and select "incl" under the "Master" option - this ensures that the mix is active regardless of were an aileron command comes from (ie. a rudder to ail mix).
You now have functioning ailerons, but, your left ail will also move as a flap with the right side slider. Next, set a mix to tell the right ail to also move with the slider.
8) Select another available programable mix. Create a mix for aux 3 (chan 8) to ail (chan 2).
9) Use the +, - value to adjust the ail travel to match that of the left ail.
10) As before, press "page" twice so you get to the screen that allows to activate trim, but this time leave trim "off" - select "incl" under the "Master" option - this ensures that the mix is active regardless of were an aileron command comes from (ie. a rudder to ail mix).
Hope this helps, if you have any questions please feel free to pm me.
t
