RE: Install the DEPS elevator system in a painted fuse
I recessed in a plate into the plate that came from ca models. This is an Eclipse. I recessed it in and will carbon fiber it at some point for the cool factor. It not something I would normally do but I didn't realize when I put the elevator tray in that I would be using DEPS. Otherwise I would have just made a side mount in the first place. I still have some dremel work to do on the plate that I put in. I just wanted to post some progress pics. If this were a glow plane I would probably have mounted in on the pipe tunnel. It's got Axi/F3A power so no tunnel.
Chris
