RCU Forums - View Single Post - Composite-ARF Lightning Build Thread
Old 12-15-2005 | 05:14 PM
  #48
schroedm's Avatar
schroedm
Default RE: Composite-ARF Lightning Build Thread
Got a couple of hours in at last on my Lightning. Started with some easy bits, well it's all pretty easy, so these are the really easy bits
Aileron mounts. This is a pretty cool idea. The aileron mounts are bolted to pre-installed mounts in the wings. Three bolts and you can whip the hole thing out! All you need do is cut the ply parts from the sheet and cyano them together. Be sure to make a left and a right!!! Then run a fillet of epoxy or Hysol along the joints to strengthen the structure. Simple as! Done!
Rgds,
Mark
Comp-ARF Rep
www.composite-arf.co.uk
ID:	370643   Click image for larger version
ID:	370644   Click image for larger version
ID:	370645   Click image for larger version
