RE: CAMPAC MEMORY TXFR FM 9C TO 9CS
Thanks for your input. GLORY TO GOD I didn't have the plane flying when the controls went wierd...I was on the ground and kept form loosing about $3,000 worth of a plane. That is where it pays off...even when the sun is going down and you want to fly so bad...you STILL check all surfaces for proper function.
If it is not the radio, then I have to check the matchboxes or the servos. I have the Hitec Digital 5945's ganged and there has been sooooo much trouble with the protocol with Futaba PCM Rx's. I will try there unless the guys at Futaba can tell me something else about the Tx.
