RE: CAMPAC MEMORY TXFR FM 9C TO 9CS
One thing to check is the servo monitor in the basic menu. It will tell you what signals are being sent to which channels. If the servo screen shows that the transmitter is sending the right commands, then the problem's external to the transmitter.
Howard was correct about the CamPac. Once it's installed, it will be formatted to fit the transmitter. If you were to put the CamPac that's formatted for the 9C Super back into a 9C Non-super, it would then be re-formatted, and you'd lose everything on it.
