Originally posted by spanky6263
You guys are great. I appreciate all the info so far. I happen to agree that if it does what you want that is all that counts. Maybe I am reading into one of your answers but when you said internal ducting were you making a reference as to the Byron does not have internal ducting on that particular model? I am assuming you were just generalizing . I have never seen a Byron F-15 so I do not know whether it is internal or external ducting. I would hope it is internal for appearance.
The ONLY internal ducting any Byron Kit has/had is the Lexan thrust tube. The fan units just set inside the aircraft and blow the thrust out the back. If you don't like the mess of the Byron, simply attach a sillicon tube to the exhaust of the engine/s and rout it outside the airframe. Simple and clean.
