RCU Forums - View Single Post - MT2 Suspension Settings
Old 12-16-2005 | 05:10 PM
Scouser
Default RE: MT2 Suspension Settings
I would only say that it is essential to bleed the shocks before putting the cap back on. Pump the shock shaft up and down to remove all the bubbles from the body. I also screw the cap on with the shaft fully compressed into the body. When it is all tightened up, the shaft should be pushed back down slowly by the oil. This is how I do mine and I have had great luck using this method so far.
