RCU Forums - View Single Post - Modifying Tail Section on Funtana 40 for Pull-Pull
Old 12-16-2005 | 06:04 PM
krayzc-RCU
My Feedback: (31)
Default RE: Modifying Tail Section on Funtana 40 for Pull-Pull
take a look at these pics. i have pull pull on this plane rudder & elevator see if you can see its a pulling action that makes everything work. the bigger servo arm will let both parts more for 3d if you are not going to 3d a standard arm that come with servo will work. look at the pic then hit me up on your ?'s
ID:	371140   Click image for larger version
ID:	371141   Click image for larger version
ID:	371142   Click image for larger version
ID:	371143   Click image for larger version
ID:	371144   Click image for larger version
