RE: Tower uproar?
Hey bud since you already have a sig fazer and I am sure plenty of experience with it, you should give a profile a try. I have a uproar 40 and it is great, but after your fazer I think it will not do much or anything more than the fazer ever has for you. I hope I'm wrong because I see under your "garage" that you have a uproar in there with out a pick. I built my uproar and then bought a H9 twist after which I got a mojo 40. The twist was the most "FUN" plane I have ever owned and the mojo is simply one of the best 3D/FUN-FLY type planes ever. Here is were people say that they just what a sport plane so they look past airplanes designed for 3D. Well 3D planes have the BEST slow speed handle of any airplanes period. They land slow as can be and are as cheap as anything. Sorry, got a little carried away but don't rule them out because on low rates they fly like an uproar or twist. When you want to, you can then increase the rates and go nuts.
If you do intend to hover with your uproar you should bring the ailerons, full width, all the way to the fus because thats were the prop blast is. skip the taper.
Think about increasing the height (top & bottom further apart) to give it some side area for KE stuff.
The lack of side area make the rudder seam inefective.
If you have questions I still have mine hanging on the wall and would be glad to help also.
Have fun building,
Dave
