RCU Forums - View Single Post - Tower uproar?
Old 12-17-2005 | 08:16 PM
freebird1
Default RE: Tower uproar?
Hi again
The plane again need a few mods, but at the price for the kit come on it can not be beat. As stated earlier it could flutter. I have a rossi 40 on mine and it has been clocked at 77MPH flat line with no flutter yet. But I knew that it could and will occur if not supported. you greatly limit that by placeing triangle stock in the stab. I do not know about other builders but I use thin CA and then go back and place a drop of 30 min Expoy in EVERY joint. I do not know about your skill leval, but the uproar can be flown slow and easy or get wild too. I say go for it with the uproar. It is an easy kit to build, and the mods are not bad either. MOJO65-9or10 made a statement that makes me think about putting mine back on the bench. I went with the taper on the Al. and I think he is right. should help with hover. Add the rudder and trutal deck and she will knife.
