RE: ultracote problems
Ross,
The Kougar below was done entirely with UltraCote, with all seams hit with a 350 degree iron and large areas shrunk at 350 degrees. Now, I do use a sock, so the actual temp of the heat getting to the material is a bit less than 350; but certainly well above 250 or 300.
That is hardly a petrified "wad" of covering... yes?
