Steve,
Very nice indeed. That scheme gives a unique new look to the Kougar! Is that the one your grandson flies?
I'm also using a sock. I wonder if different colors have varying temperature tolerances? I know that the neon orange in particular is very sensative to higher temps. And now that I give it more thought, it seems like the darker colors are a little more tolerant than others. I've only used white, neon orange, metallic purple and charcoal pearl and the white and orange seem to shrink much faster than the purple and charcoal.
In any case, the best advice is to test and use what works best for you. I'm sure I have nowhere near enough experience to be considered an expert. More likely a lucky novice with patience and decent results
