RE: Brison 5.8
...Take the six screws and stud out of the hub...Stick the stud through the backplate and drill six holes in it...Get some grade 8 10-24 allen bolts to hold the prop on...use the stud as a drill jig for the prop...Check the six prop screws every time you fly the plane, the prop will compress and when the screws start to get loose they will shear off...[8D]
