RCU Forums - View Single Post - Parkzone Typhoon - I need help!
Old 12-20-2005 | 07:00 AM
jmir
Default RE: Parkzone Typhoon - I need help!
VT BARNSTORMER
Thanks for the suggestions and reassurance as to being able to learn how to hover with the Typhoon.
I use a Thunder Power battery which is longer than the stock battery and fits all the way to the back. I've got plenty of power. I could experiment with some weights to the back of the plane at small increments.
I can check CG and measure the changes as I go along when adding weight to the back. But, how do you check to make sure the wings are balanced?
What's frustating is that I can do several 3D maneuvers with my Edge 540, but can't really do a single one with the Typhoon. That's why I'm beginning to think that my Typhoon may need some adjusting.
Thanks again for your comments. I appreciate all the help.
