RE: Multiple servos in an Ultimate
Just y the top wing and the bottom wing. Like you would on a monoplane. Then plug the top wing in aileron channel and the bottom wing into the aux 1 channel. Then setup the flaperon mix. When on a y lead the servos will go different directions so this should have everything working in the right direction.
