RE: Carburetor... how do glow engine carbs work?
The intake stroke of the piston creates a negative pressure under the carb which pulls in air. The air moves past the fuel spraybar, pulling fuel into the carb by the venturi effect. The amount of fuel is regulated by the needle valves. Muffler pressure helps the engine draw fuel at idle, when the negative pressure is the least.
Dr.1
