RCU Forums - View Single Post - Caliber 30 Flight problems
Old 12-21-2005 | 10:00 AM
echobot's Avatar
echobot
Default RE: Caliber 30 Flight problems
ORIGINAL: ngbninja
Well there is no binding what so ever, i had recently purchased 550 carbon blades and used them do you think they were the problem?
Could an adjustment to the air bleed valve be an answer to the high throttle starts?
I would put the old blades on and see if the delay problem goes away. What do you mean by high throttle starts? The engine should start just above idle. If the engine is starting up to fast, make sure you don't have the idle up switch on.
