Go Back  RCU Forums > RC Helicopters > Kyosho Helicopters
 Caliber 30 Flight problems >
Kyosho Helicopters Discuss all Kyosho heli topics here.
Old 12-20-2005 | 07:16 AM
Default Caliber 30 Flight problems
Hello,
I took out my cal 30 for the first flight today and had several problems:
1. Engine started a few clicks under half throttle
2. Cyclic control inputs were delayed in hovering
For example if i pushed the cyclic stick forward the heli would move forward a few seconds later
which made hovering impossible.
thanks
Old 12-20-2005 | 08:25 AM
echobot's Avatar
Default RE: Caliber 30 Flight problems
Either your servos are very weak or you have some binding problems.
Old 12-20-2005 | 09:20 AM
My servos are futaba 3151's so i dont think they are the problem, I will investigate the issue of binding
thanks
ngb
Old 12-21-2005 | 09:46 AM
Well there is no binding what so ever, i had recently purchased 550 carbon blades and used them do you think they were the problem?
Could an adjustment to the air bleed valve be an answer to the high throttle starts?
Old 12-21-2005 | 10:00 AM
echobot's Avatar
ORIGINAL: ngbninja
I would put the old blades on and see if the delay problem goes away. What do you mean by high throttle starts? The engine should start just above idle. If the engine is starting up to fast, make sure you don't have the idle up switch on.
Old 12-21-2005 | 01:37 PM
When I go to start the engine it will only start at half throttle on the TX, idle up hasnt been on. I will check with the kyosho blades next time i have spare flight time.
Ngb
Old 12-21-2005 | 02:25 PM
Check that your washoutguide is locked in right position. If it comes loose the heli will feel very instable. It's very hard to fly it.
For the engine. Check that the carburator is fixated to tha crankcase. Fueltubes are ok. No leakage. That the engine is not set to rich/lean.
Don't ask how I might know that.[8D]
