RCU Forums - View Single Post - Let's Loft!
Thread: Let's Loft!
Old 12-22-2005 | 12:07 PM
Chad Veich
My Feedback: (60)
Default RE: Let's Loft!
Geardaddy, Compufoil will indeed reduce this whole process down to a few minutes and is well worth the money. I have it and have used it but have not gotten really comfortable with it yet. One thing, not every airfoil that one may need for a scale airplane is available in Compufoil and I have not reached the point where I can edit the existing airfoils to get where I want to go. Guess I need to learn a bit more about interpreting airfoil coordinates! Still, lofting the old fashioned way is a good skill to know and have in your "tool box" even if you are using some form of lofting software most of the time. I'd be very interested in somebody doing a tutorial on how to really use Compufoil effectively.
Mike, if you have any sort of drafting skills at all then you are ahead of the game when it comes to learning CAD. The majority of the basics necessary to draw up plans can be learned quickly. However, learning to really use CAD to its' full potential may take years! I'm at the point where I can find ways of doing most of what I want to do but my gut tells me there are more efficient methods that I have not learned yet. I really am considering taking some night courses in ACAD just to learn some of the finer points. I use ACAD every day at work, and have for the last 6 years or so. However, I use it in a pretty limited capacity for my job. I've learned far more drawing airplanes than I have learned at work!
Kelsey B, thanks for the kind words. Generating the airfoils can be easy or quite difficult depending on what tools you have available and what airfoils you need. For those designing scale models I highly recommend you bookmark "The Incomplete Guide to Airfoil Usage" found here: http://www.ae.uiuc.edu/m-selig/ads/aircraft.html
This site lists the root and tip airfoils for a huge number of aircraft. Some airfoils are quite easy to find references on while others can be impossible. Of course, if you're not going to use the scale airfoil then the whole process may be much simpler.
