Let's Loft!
I do appreciate the inputs on this. I've been watching Chad's work on the [link=http://www.rcuniverse.com/forum/m_7335038/tm.htm]1/6 Scale F4U Corsair Group Build[/link] and thinking to myself that I need to learn to do this. I'm very computer literate, but my impression is that Autocad is pretty expensive and that the learning curve is pretty steep for casual/occasional users. So I'm very interested to hear what alternatives are out there to apply to the hobby.
Tom
Tom
My Feedback: (60)
ORIGINAL: fockewulf37
Sorry...
Ty
Sorry...
Ty
ORIGINAL: SMUGator
Tom
Tom
PS - The method shown here for lofting can be done with a pencil and paper as well. The CAD program does not make one a better engineer, it's simply a tool like any other. Often CAD just allows bad designers to turn out bad designs at a much faster rate!
I'm pretty comfortable taking an existing profile and adding the right ribs, infrastructure, etc to make a good strucutural build. To date, I've mostly done it with a ruler and some french curves. I don't have any formal training with drawing things - just a general understanding of what the result should look like. The structural aspects of building are my strength. Then I have to nurse my work through the finishing stages.
Thanks for bumping this to the top. Chad, If I were willing to invest up to $1K in a CAD program, what would you recommend?
Tom
Thanks for bumping this to the top. Chad, If I were willing to invest up to $1K in a CAD program, what would you recommend?Tom
My Feedback: (60)
ORIGINAL: SMUGator
Tom
#31
Chad, , ,
Any luck in getting those links to work again?
They were great step by step images.
I remember seeing them when you first posted them, then shortly after they were gone.
#33
Probably a dumb queston....but...any way that Google's free Sketchup program will do simple resizing of ribs? I envision putting in tables of particular rib; having Sketchup draw the ribs, and then do all of the resizing as shown in the very first set of drawings on this thread. I do not know Sketchup, but see that it has some very powerful functions that might work for a simple guy like me. thanks Rich
#34
I knew you could design fuselage former with compufoil but I did not know I could make a fuselage drawing as well, I think I'll give it a try and see what happens.
#35
My Feedback: (35)
Do any of my fellow scratch builders know where I can get a cad program for home use, don't need anything fancy, just trying to make rib patterns, not designing my own planes. I have a lot of plans where al they give on the plans is the root rib and tip rib template, and leave you gessing for the rest. pay premium for the plans also. If anybody has a program or copy of one, willing to pay for it .thanks so much for the tutorial.</p>
#36
My Feedback: (35)
Chad, thanks for the tutorial, Just a dumbass from Pa. this might be a little too much for me to understand, My very first attempt at wing ribs. If you had the time, explanation in lay terms would be greatly appreciated, no cad program,or understanding of one, would like to learn though. Thanks very much [email protected].
#37
Chad,
I finally got around to reading this tutorial. Very nicely done! These seems like a good approach to me, particularly if you are used to working in CAD. I am going to grab me a set of root and tip airfoils and give this a go!
CWCOPE
CWCOPE
#38
My Feedback: (60)
rccrasher65, email sent.
Charles, this will be a no brainer for you I'm sure. I loft fuselage formers using this same method as well. Even though this method is only truly accurate on straight tapers I can usually generate the intermediate formers of a curved fuselage by lofting them using this method and then "massaging" them by eyeball to fit.
#40
Great tutorial! Here's how I do it but a little old fashioned. I now have rib templates with holes to locate wing jig build rods. This is for a future project, Gordon Israel's REDHEAD. The drawing is from taking measurements from Wm Kerka's 3 view. Rough cut parts separated by blue foam spacers, sand and done in ~2 hours.
