RCU Forums - View Single Post - new.. fliton infinity 90
Old 12-22-2005 | 04:50 PM
  #159
wagen017
Default RE: new.. fliton infinity 90
well, the YS 110 will be more than adequate power. The plane itself is well built, just always have CA handy to glue the striping back on, I think by now I have glued all of them back on. I found the engine mounting a bit flimsy. The engine I mounted had a lot of vibration initially (later I mounted it on rubber, also the exhaust). I think if you add epoxy to all the joints you will be OK. After a not so hard landing the bottom plate where the landing gear is mounted broke out (I used the stock metal M4 screws), so now I replaced this with a thicker and strenghtened piece of wood, and replaced with M5 plastic screws.
I needed to pin the CA hinges when an elevator half broke of (see earlier in thread), never needed to do that, but you better check anyway.
Have fun, it's a great plane!
volkert
