RE: Toro won't rev
JON
I HAVE 2 OF THESE 2BBL TORO'S THAT I HAVE MODIFIED TO USE A 1BBL WALBRO CARB. THINGS FOR YOU TO CHECK ARE TO MAKE SURE YOU HAVE THE CARB GASKET ON SO THE PULSE HOLE IS OPEN TO THE PUMP. ONE OF MINE HAD THE CYC. BASE GASKET ON SO IT WAS BLOCKING HALF OF THE TRANSFER RUNNER OFF. THE 2 REED VALVE ON ONE OF MINE WERE BAD AND DIDNT SEAL SO IT WAS GETTING AIR IN THE TOP HOLE ALL THE TIME. YOU CAN CHECK THIS BY COVERING THE TOP HOLE IN THE CARB WITH UR FINGER THEN TRY TO GET IT THROUGH UR LEAN RPM SPOT. THERE IS NO FUEL ON TOP JUST HIGH RPM AIR TO MAKE IT GO LEAN AT HIGH RPM. MUST BE A POLLUTION THING. I HAVE 2 OF THESE CARBS AND THEY SEEM TO TRANSITION THROUGH THE RPM RANGE VERY GOOD. IV JUST WORKED ON MY PORTING TO THE POINT WHERE THE 2BBL IS TO SMALL. IF YOU CANT GET URS TO WORK WE CAN TALK ABOUT SOME KIND OF TRADE FOR 1 OF MY 2BBL'S. BOTH OF MY CARBS WERE SET PRETTY GOOD AS THEY WERE SO I DIDNT TRY TO CHANGE THE SCREW UNDER THE PLASTIC PLUG. KEEP US POSTED!!
FARMER TED
