RCU Forums - View Single Post - Sites for learning 3D
Old 11-17-2002 | 12:53 PM
EXCAP232
My Feedback: (12)
Default Sites for learning 3D
Originally posted by RCToon
Yes thats the kit. CG is OK as per plan slightly aft actually. Its got a OS LA40. Prop 10X6 maybe I should try a 11X4 or something.
The LA engine would be marginal for this plane to do what you are attempting. Trying the 11X4 would help. If you can get a FX 46 which would be a better choice. You may have access to Irvine engines. I have had very good luck with the 0.46 and the 0.53 which is in the same case and produces 1.7HP instead of the 1.4HP
A CG a little aft of the recommended might also help. Just do it a little at a time. Check the lateral balance and make sure you have enough right thrust in the engine for good vertical uplines.
EXCAP232
