ARESTI prop help
I have an Aresti with a OS 46FX
If you have this plane with this engine what prop do you recommend is the best?
What do you use?
What is a good prop for vertical as well as speed performance, like a good all around for this plane?
And also I am using those APC props(the gray plastice ones with not flat but pointy edges on them)
Thanks, Andrew
