RCU Forums - View Single Post - arf Aresti 40
Thread: arf Aresti 40
Old 08-04-2003 | 03:03 AM
AdrianM
Default arf Aresti 40
1. Use longer servo arms like the dubro heavy duty arms.
2. Solution A: If you have a computer radio set the end points so you have what you need up and down.
Solution B: Angle your servo arms ~30 deg forward and re set you ailerons so the trailing edges line up. This will give you more up than down throw. To get more or less diffrential in travel angle the arm more or less.
