All worked out good on this Ail.&Elev. modification indeed well worth the 'balsa dust' the simple trick is to counter sink and then provide clearance for the hinge line pivot point. A Dremel makes quick work of this providing the needed 'clearance' so the Robart hinge can pivot about.. control surfaces LEADING EDGE
