Flaps
Guy's, to program in flapperons you need a computer radio & have to connect the right aileron to channel 1 & the left aileron to channel 6 on your reciever. Your radio manual will explain how to program for this. What flapperons do is allow you to use your ailerons as you normally would & you can turn the flap control & both ailerons will drop down to what ever amount you desire, while ailerons are down as flaps you still have aileron control on right stick. example, coming in for a landing, drop flaps about 10 degrees & you can still use right stick to keep wings level for landing.
