RCU Forums - View Single Post - Su-do-khoi .60 What engine do you use?
Old 11-20-2002 | 11:23 PM
fxstbi
Default Su-do-khoi .60 What engine do you use?
Thanks for the info Tailtwister. I am just about finished with the fuse destrct... OOPS I mean CONstruction. I intend to leave some of the sheeting off of the fuse and continue with the wings and tail feathers. I am going to be assembling and checking the CG all the time and plan my radio installation accordingly. I am going to use my Webra 1.2 and probably use two elevator servos in the rear of the plane. I'm keeping the sheeting open in all the areas that need to be accessed to make this as easy as possible. I think that if you would build a couple of these it wouldn't be too bad. Trying to figure out the manual and the plans makes it a struggle. I think the pay off will be in the flying. Pete
