RCU Forums - View Single Post - Su-do-khoi .60 What engine do you use?
Old 11-20-2002 | 11:52 PM
TailTwister
Default Su-do-khoi .60 What engine do you use?
I too hope for an airborne pay off! I just can't imagine how it will fly. It is said to be super easy to hover and 3D. It should retain some of the Morris "whip crack" fun fly abilities as well. At a minimum it isn't a plane you see everyday! Have you planned a finish yet? I'm going to try a look similar to the Hanger 9 SU-31. I'll substitute "TailTwister AEROBATICS" where they have "Hangar 9 AEROBATICS" on the wing. I'll probably use Monokote Cub Yellow and True Red. Good luck with the "kit". The fuselage is said to be the worst as far as the instructions go. The wing's only problem is getting it flat. The tail is the same. Keep it light. Did you notice the huge discrepency between the plans stated wing area and the advertized area? That kinda' got to me, but I was over it pretty quick. You'd figure they would know the planes specs by now.
