RE: Zama Remote Primer bulb?
Les:
The primer isn't required. All it does is fill the carb with fuel. Turning over the motor a couple of times with the choke on does the same thing. Small motor shop should have lots of used ones kicking around. Just get one with the same throat size. Linkages can be modified for use.
