RCU Forums - View Single Post - Zama Remote Primer bulb?
Old 12-27-2005 | 07:45 AM
teddywilk
My Feedback: (10)
Default RE: Zama Remote Primer bulb?
IF ITS A REMOTE BULB JUST TAKE THE HOSES OFF AND HOOK THE HOSE FROM THE TANK TO THE FITTING ON THE CARB. IF ITS BUILT ONTO THE BOTTOM OF THE CARB U CAN CUT A PIECE OF 1/16 NEOPRENE RUBBER THE SAME OUTSIDE DIA AND USE THE METAL CLAMPING RING AND DO AWAY WITH IT THAT WAY. THIS FLAT RUBBER DISC WILL STILL WORK AS A PRIMER AND COULD SAVE SOME NEEDED SPACE.
FARMER TED
