RCU Forums - View Single Post - Engine question for Funtana 90S
Old 12-27-2005 | 09:10 AM
Eric.Henderson's Avatar
Eric.Henderson
Default RE: Engine question for Funtana 90S
I have seen a bunch this size Funtanas and ,]many different motors on this plane at my local field. I personally ran a YS 1.40L with no problems. The YS 91 guys complained. The Saito guys complained a lot until they put bigger ones on the front, 1.50 I thiink?
The 91 OS was marginal. Your plan to use a 1.20 2-c should work well. If not a YS 110 does the job.
I did retrofit an A type (No nose-ring) hydemount to quieten down the snare-drum effect on the wings.
If you already have motor just stick it on and see what happens. You can easily change it later.
Regards,
Eric.
ORIGINAL: loupus
Hi Guy's, been trying to sort through the Hangar 9 Funtana S90 threads but with an extra slow server at the moment it has been very tiresome.
Would a TT120 be too much motor for this plane?? or would I be better going with a TT .91 / ST .91??
Thanks in advance.
Rod.
ID:	376248   Click image for larger version
