RCU Forums - View Single Post - NEXSTAR...TO...WAR DUCK !!!!!
Old 12-28-2005 | 04:28 AM
  #66
Lureman
Default RE: NEXSTAR...TO...WAR DUCK !!!!!
Well I have started my conversion. I flew yesterday and had 6 flights in when things got soggy. I could not figure out why my trim was changing every flight and the engine would miss every now and then when it never did before[] So I put it in a hard climb till the engine quit, it was the only time it would miss. Never on the ground did it miss just in a climb. So I glided the plane down landed perfect on the ice runway we plowed and took the wing off I suspected a cracked tank. I was half rite the screw for the tanks rubber grommet was loose and fuel was running out of the tank into my nexstar soaking all the foam in the fuse I pored out about 6oz of fuel. went home took off all covering on fuse to let it dry out (the covering was coming off anyway I had alot of tape on it already) So the conversion begins I'm thinking of changing the tail to a round one to make it look like a stand off L-19 Its a cool idea( nexy-19) any thoughts!!!!!!!!
