RCU Forums - View Single Post - Official GP Reflection Build Thread!
Old 12-28-2005 | 10:43 AM
  #128
3DNobody's Avatar
3DNobody
Default RE: Official GP Reflection Build Thread!
ORIGINAL: Scorpio
Also I have one question any of you guys have issues with your ailerons not centering my ailerons don't want to re centre after I give full movement, this is cause big problems in flight?????????????? any suggestion or answers would be appreciated.
You have to make sure that every linkage in the aileron system moves freely. I had this problem and the culprit was the z bends. I did not get them free enough to start with. Once I fixed that, it worked just fine. Don't fly the plane if they are not centering properly...it will be a handfull. In order for this plane to perform at it's best, everything needs to be exact and precise. If you take the time to do this up front, the plane will reward you with some great flights.
To the rest of you guys that are wanting a "build thread"...Read through this thread! There is not a Step-by-Step guide in here (that is what the manual is for. ) but there are valuable building tips and experiences that many of us have posted in here that should make your Reflection expereince really good.
HTH
-Jeff
