ORIGINAL: cchrider
so even tho duratrax distributes them, can I still get them for like 20bucks?
cchrider
yes, typically duratrax is a bit cheaper... but like was said above, it's not the same quality as the OS labeled engines..
with that said, go ahead and go cheap if you have to... but keep in mind that Jack Roush don't use duratrax parts on his engines... my suggestion is to get the best quality that you can afford, it'll pay off in the long run..
