Dave Patrick Ultimate ARF
scott hayden:
I am pulling the RCS 1.4 off to install on a lighter plane once i build or start building it next month. The RCS with 16 x 8 doesn'ty have the verticle i need to do point rolls on the up lines. I will try a 18 x 6 mejzlik, and APC before i pull her off. She is scale flyer with this present set-up. She was one bad girl with the satio 180 on 15% nitro and an 16 x 8 APC on a pump with a 20oz tank. I am 12 3/4 lbs with the RCS 1.4. The motor will hold the plane on the prop for about 3-5 seconds at 7/8 thorttle and i don't have any pull out on that deal. The RCS is a sweet motor as i plan to put this on a 9-11 funtana depending on my building weight as i see them under 10.5 lbs with most builders........
