RCU Forums - View Single Post - Dave Patrick Ultimate ARF
Old 11-22-2002 | 12:35 AM
X-Cellant's Avatar
X-Cellant
Default Dave Patrick Ultimate ARF
If you get one, don't be sucked into using the supplied hinges. I had an eleavator hinge brake, doing the Blinder. luckley I found it before I lost the hole elev. It was a royal pain to fix, and now I have to wonder about all my other hinges. : (
Mine has a Sato 180 and flys like a dream. I had 2 flying wiers brake in flight. I have replaced them, and the pull pull cables with heaver cable and thay are fine now. I am not shure if the flying wires are a must ( because my tail stayed intacked after thay broke), but with the stunts I put this plane through I am glad thay there.
So replace the cable and the hinges and go punch some holes in the sky.
