RCU Forums - View Single Post - Inverted Engine and Cline regulator
Old 12-29-2005 | 08:59 PM
Flynow1
Default Inverted Engine and Cline regulator
Has anyone ran into the problem of a Cline regulator not allowing the engine to get to max RPM? The engine(Satio 100) will reach about 10K max ,APC 16x4 so it's happy at about 9700. With the regulator about 8400 is it I've been using the regulators for inverted engines without problems, this is the time that I haven't been able to just plumb it and fly. I've tried 2 regulators, same thing! I changed the tubing (T's also) all the way back to inside the tank, then tried a new tank. The system holds pressue just fine. The needle is out about 4 turns, leaning it out only gets me about 300 hundred RPM more . Any thoughts?
