RE: Balancing
Balancing a 2-cell Lithium pack is much less critical than balancing a 6s to 10s pack.
You can charge each cell separately to balance the pack. It may be easier to simply measure the voltage of each cell to see if it is even needed. If the cells are within .005v of each other, you are fine.
