RCU Forums - View Single Post - Ring Replacement Question
Old 12-30-2005 | 09:06 PM
RaceCity's Avatar
RaceCity
Default RE: Ring Replacement Question
It wouldn't hurt to LIGHTLY scuff the cylinder bore with some fine (400-600grit) wet-or-dry paper and oil. Avoid any sort of vertical scuffing, and be certain to clean the liner thoroughly before use. Make the first few flights at a conservatively rich setting to let the ring settle in and you should be fine.
'Race
