RCU Forums - View Single Post - Rodeo- Editing the model parameters
Old 12-31-2005 | 05:33 AM
rc-rodeo
Default RE: Rodeo- Editing the model parameters
Hi,
@BLT
The limit of zoom is set by the keys A-Z, you can also see the values changing in the flight menu 'Main view - Viewer setup' (last entry in this menu). The actual words in your version can be different, I tried to translate my german menu.
Additionally you can switch from F5 to F6 to do an automatic zoom when the model is far away.
But generally spoken, in foto sceneries you should zoom OUT very strongly.
@Matt,
I used the expression internal editor for the AFPD menu 'Edit aircraft'.
When we create a new aircraft, it's very important to open this menu in an early stage, because AFPD does some calculation from the graphics and writes the data into the TMD. Then we can go on to edit these values.
I wish you a Happy New Year, guys!!!
Karl-Heinz (Rodeo)
