RCU Forums - View Single Post - how much harder would it be
Old 12-31-2005 | 06:42 AM
CafeenMan
Default RE: how much harder would it be
CG doesn't change unless you change the size or location of a flying surface.
I think you're making a good decision to convert to tail-dragger. They weigh less, are easier to build (and maintain) and have less drag.
Good advice about throttling up slowly and also about taxiing around a bit to feel it out. Be sure to put an air-filter over the carb so you don't suck a lot of dirt into the engine. A piece of ladies hose rubber banded on will work.
