RE: how much harder would it be
[quote]ORIGINAL: CafeenMan
CG doesn't change unless you change the size or location of a flying surface.
You may want to rethink that statement !!!! If I change the material I use to rebuild and it is heavier then the original it IS going to change the CG. That would be like adding or subtracting weight from some where. Besides, anytime you work on a plane it is a good idea to check the CG.
ENJOY !!! RED
If I rebuild the tail with OAK instead of balsa, it's sure going to be one heck of a take off !!!!
